Temp seems high
Old Jun 8, 2020 | 07:14 AM
03jawja's Avatar
Default Temp seems high
In around 90°, my temp is about right at the 210 Mark or son in traffic. My ac only really works when im driving for a bit, the minute i sit in traffic or idle with ac, it jumps to 215-220. What could be the issue?
Old Jun 8, 2020 | 09:12 AM
Generally, high temps only at low speeds are caused by airflow issues (bad fan clutch or shroud, radiator blockage, etc.). Have somebody turn off the hot engine while you watch the fan blades. They should stop spinning almost immediately. If they keep spinning after the engine stops, you probably have a bad fan clutch. Also, check to make sure the radiator fins aren't clogged with mud, bugs, leaves, etc.
Old Jun 8, 2020 | 09:15 AM
03jawja's Avatar
I will definitely look into that. I wanted to go to efans anyway. So i might look into that this week. I will check radiator today
Old Jun 8, 2020 | 05:59 PM
03jawja's Avatar
Well took Tom's advice...radiator was filthy..dust, leaves, plants, bugs, and mud. After about 40 mims of trying to vacuum, brush , clean radiator without bending fins. Going for a drive..we will see!
Old Jun 8, 2020 | 06:01 PM
Haha... I think that's definitely a move in the right direction.
Old Jun 8, 2020 | 07:46 PM
Looks like you were vacuuming your lawn........
Old Jun 8, 2020 | 09:58 PM
03jawja's Avatar
I know..i let it get bad, Lesson learned. Ran cooler today, ac still sucks, may have to change clutch fan or install efans. Looking at a bigger radiator online tonight!
Old Jun 9, 2020 | 01:45 AM
A/C could also be low on refrigerant. Then it looses capability to cool. When was the last time it got checked? Might just need a refill.
Old Jun 9, 2020 | 08:33 AM
I got an aluminum radiator from a place that Christine suggested (Engineered Cooling Products - Aluminum Radiators) that's been fantastic. They also have them with built-in electric fans if it's in your budget. That would be the way to go, IMO, if you want to buy once and cry once.
Old Jun 10, 2020 | 08:35 PM
03jawja's Avatar
Ive been thinking about getting on of those. These Tennessee summers can be rough!
