Are there any good additives for old fuel?
Old Nov 6, 2014 | 08:52 PM
MountainMermaid's Avatar
MountainMermaid is on a distinguished road
Default Are there any good additives for old fuel?
I am not a mechanic and I have minimal tools. I am trying to get a 1995 S10 Blazer going that sat for 11 years. Someone is helping me who knows more than I do. Unfortunately, the car was started, and it ran for a total of about a half hour, without pulling the plugs and adding oil, or changing any of the fluids, including the gas (tips that I have seen online since.) The fuel filter was changed. The car actually ran pretty smoothly once it warmed up, and it didn't seem to be smoking at all. When shut off, it would start right back up by just turning the key. There is between 3 and 4 gallons in the tank. How bad is it to run the rest of this bad gas through the engine? Where the car is located, it would be difficult to drop the gas tank to siphon the fuel, and my helper isn't willing to try, even though this would be best. It needs to be towed, not trailer-ed so he wants the engine on for power steering and brakes (road is really bad). Should I insist on dropping the tank or figure out how to do it myself? Or, are there any "really good" additives that would help? How much will an additive help? Someone online suggested adding some high octane gas to the old gas? Will this help? HELP!!!
Old Nov 7, 2014 | 08:03 PM
rexazz2's Avatar
I am a big fan of Sea Foam fuel treatment but 11yrs is beyond my ability to guess if it would be any help
Old Nov 8, 2014 | 07:55 AM
abig84's Avatar
if theres only 3-4 gallons in it go get as much new gas as you can and add it in, should help a bunch once you get the fresher gas mixed in with the old crappy ga
pretty impressive for that thing to even start with that crappy of gas over that long of time.
Old Nov 8, 2014 | 03:14 PM
rexazz2's Avatar
probably was actually ethanol free
dhud64
Jan 16, 2015 04:46 AM
MountainMermaid
Nov 7, 2014 04:04 AM
musclecar70sfan
Apr 24, 2010 01:41 PM
zero psi
May 21, 2005 04:50 PM
