ticking noise in 02 Blazer
Old Jan 8, 2010 | 08:35 AM
mmagana's Avatar
mmagana is on a distinguished road
Default ticking noise in 02 Blazer
I have a 2002 Blazer 4.3L engine with 117,000 miles
I'm hoping to get some suggestions about what could be causing a ticking noise I've started hearing coming from engine recently.
It seems to stop once I get the engine running at normal temp.
Over the last year I've replaced water pump, radiator and most recently fuel pump and fuel filter (after the blazer died in traffic with no warning)
It's due for an oil change in another 100 miles and will be changing it this weekend.
I've also noticed since the fuel pump replacement a month ago that my gas mileage has gotten worse.
Old Jan 8, 2010 | 10:03 AM
mr.vls's Avatar
Ticking noise from the engine can be caused by lifters/valves or a bad bearing on one of the engine pulleys.
Old Jan 8, 2010 | 10:41 AM
rriddle3's Avatar
I agree that it sounds like it might be an upper engine lubrication issue. Try doing a treatment with Auto-Rx and/or using a 10W30 oil if you are not already.
Old Jan 9, 2010 | 08:18 PM
NOs's Avatar
NOs
NOs is on a distinguished road
Last weekend I ran into this problem on a '97 4.3L. Read many posts pertaining 2 this. u can try the engine flush method with the oil. We replaced 12 lifters that were pounding away but it still makes a bit of a clacking noise. Did all work as manual & experience would / should have panned out. Got timing dead on.
marlboro124
20
Oct 6, 2011 11:55 AM
Killah_K
Jun 21, 2010 04:35 PM
bammontana
May 9, 2010 12:53 PM
breakyadown89
Oct 17, 2009 11:45 PM
pmezo
May 16, 2009 12:18 AM
