Time to get over my head!
Old Jan 9, 2010 | 06:03 AM
  #31
old skool luvr's Avatar
Originally Posted by BlazerGuy2001
So ive decided to take another path with this engine idea and go back to swapping it with a more powerful engine....however i think the 5.3L V8 is a little on the small side....a 350 small block should do the trick.
that 5.3 will out perform the 350. higher reving, quicker spooling, and better on the mileage. don't forget, your trying to shoehorn this V8 into a truck that was designed for a large 6, the power to weight ratio is gonna go up large!
Old Jan 9, 2010 | 06:37 AM
  #32
BlazerGuy2001's Avatar
ok assuming that the 350 and 5.3L are about the same power, regardless of which one is better. From what i have read it seems much easier to fit a 350 into a blazer, and they are also less expensive and easier to find parts. Is this correct?
Old Jan 9, 2010 | 07:31 PM
  #33
anyone know how easy they are to fit??
Edit: decided if im going to go with a 350 why not just go all the way to a 383 stroker with it....no reason not too give me your opinions pllllleeeasseee
Old Jan 10, 2010 | 08:01 PM
  #34
Ok i have made up my mind on the engine i want to use. Im going to use a 5.7L Vortec engine and a stroker kit with it to bring it to 6.3L. Also i will be using a 4L60E tranny with it. Does anyone see any problems with this swap?
Old Jan 11, 2010 | 07:00 PM
  #35
^^^ yeah, you're gonna twist the s**t outta your truck!
Old Jan 11, 2010 | 07:32 PM
  #36
bigkhans's Avatar
bigkhans is on a distinguished road
I stayed with the 4.3 and had it bored .60 over, stock crank and cam. I still have good mileage and lots of power without having to modify everything. I did replace the timing chain, oil pump, lifters. I had the machine shop install the crankshaft and bearings along with the new pistons w/ rings and install the heads. Total was somewhere for about $900.00. Def worth it to me knowing it was done right.
Old Jan 11, 2010 | 08:05 PM
  #37
old skool luvr
Is the frame really not built up to this? What can i do to bring it up to spec?
Old Jan 11, 2010 | 08:43 PM
  #38
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
yea s10 frames really are not made for that kind of horsepower. if you really want that kind i'd be looking for a k5 blazer or an old k10 truck. if it was my truck and i wanted to do an engine swap i'd be looking at a small block v8. or get your v6 bored out to a common overbore. cause like said above. your gonna have a nasty frame twist
http://www.youtube.com/watch?v=lfPkC...eature=related
*just in case
Old Jan 11, 2010 | 08:48 PM
  #39
The vortec 5.7L is essentially a 350 small block V8 with different heads on it....and i really dont have the money for a K5 or K10...is there anyway to avoid frame twist with that engine?
Old Jan 11, 2010 | 09:10 PM
  #40
Banned
i'd go with an overbore common spec on the v6. look at the bright side while your getting new pistons, etc. your basically getting an overhaul
