Timing chain replacement?
Old Sep 5, 2011 | 11:26 PM
ComputerNerdBD's Avatar
ComputerNerdBD is on a distinguished road
Default Timing chain replacement?
Hi everyone. I am approaching 107k on this original 98 4.3L. I realize timing BELTS have to be replaced at a certain mileage (my mom has a Toyota product (she gets pissed when I call it the "riceburner". Piece of crap. Not only with the Toyota recalls, but the metal is so thin that the car wash left a crease in the metal.) that has around 80k and the dealer replaced the timing belt recently.), but what about the timing CHAINS on these 4.3L? Is there a required replacement mileage to prevent it from failing and destroying the engine?
Old Sep 5, 2011 | 11:46 PM
chris015's Avatar
Im honestly not sure,Ive always tested it this way on the older blazers. Pop off the distributor cap so you can see the rotor,then turn the crank back and forth with a breaker bar/extension/socket and see how much play it takes for the rotor to react.
Old Sep 6, 2011 | 12:05 AM
xgiovannix12's Avatar
best thing to do is next time the trucks at a mechanic is make them check it
a friend of mine checked it the last time they worked on my truck
ComputerNerdBD
May 22, 2016 07:29 AM
drblaze
18
Jun 22, 2011 01:58 PM
gabenton
Mar 26, 2010 08:23 AM
HomeGrown
Feb 10, 2010 04:19 PM
dpannazzo
15
Dec 17, 2009 01:18 PM
