timing at idle
I have a 2000 blazer 4x4 2dr 4.3L and I have searched all over the forum and can't find anything that can tell me what the timing should be for this engine.
My scanner shows the timing at around 19 degrees while idling, and while I
have a timing light attached to cylinder no. 1 the mark on the dampener is actually about 2 inches to the left of the timing tab mark on the block at idle, should it be this far off?? I have checked for vacuum leaks and has 22 inches of vacuum at idle. thanks in advance for any responses!!!!
The reason why you are not going to find that information is because is it highly dependent on the conditions and the vehicle.
My old scans on my '00 Bravada showed anywhere from 15 to 22 degrees advance during hot idle.
You cannot use a timing light on these engines without first installing a scale on the balancer and a pointer on the engine block. The pointer would need to be adjusted for true TDC #1 at 0*.
Doctorvette
Nov 5, 2012 11:57 PM
Denominator
Sep 23, 2010 02:40 PM
hotrodln
17
Apr 26, 2010 07:32 PM
Denominator
Apr 25, 2010 06:31 PM
