timing mark question
Old May 27, 2009 | 05:52 PM
dgh91's Avatar
dgh91 is on a distinguished road
Default timing mark question
i have a 4.3 vorec its a 92 i was wondering where to go by on timing marks i know where there at but cant see any numbers or marks to go by
thanks
Old May 27, 2009 | 07:53 PM
Timing is to be set at 0* TDC. This should be the largest notch in the timing tab.
But you have to disconnect the tan/blk wire under the HVAC case just to the left of the transmission tunnel inside the truck prior to attempting to set the timing. You may have to pull back the carpet a bit to see this connector. Do not disconnect the 4 pin plug on the distributor.
Neenie217
Jul 25, 2014 02:19 PM
kennycraze
Apr 5, 2014 05:55 AM
Little Roober
Oct 30, 2011 09:29 PM
blazingtrails93
May 22, 2011 05:58 PM
deedub711
Apr 19, 2011 09:11 PM
