Lost my mark on rotor.
Old Oct 30, 2011 | 06:21 PM
Little Roober's Avatar
Little Roober is on a distinguished road
Default Lost my mark on rotor.
I'll skip the bs and get right to the point. After getting my distributor in and my truck started and running great...for a few minutes...the distributor kept making a sound like a piece of paper in a fan blade. So I shut it down and realized that it wasn't aligned with the mark I made, so I pulled out the distributor and lined it up again. Shortly thereafter I realized that the rotor spins, so of course it wasn't lined up. Now, how do I find out where the rotor should be? Thank you.
Old Oct 30, 2011 | 06:23 PM
xgiovannix12's Avatar
the rotor has a tooth it should only enter the shaft the way its suppose to be
If the tooth on the rotor is gone you should replace it
Old Oct 30, 2011 | 06:29 PM
The rotor is fine and brand new. Pretend I didn't mark the dizzy before I pulled it off though. How would I find out which way it's supposed to point?
Old Oct 30, 2011 | 07:58 PM
This should help:
EDI Engine Timing
Old Oct 30, 2011 | 09:29 PM
That's exactly what I needed. Thank you very much. I'm so close to having it running again I'm doing this.
rexazz2
Apr 8, 2013 06:50 PM
garrett8784
Jul 16, 2012 12:07 PM
blazingtrails93
May 22, 2011 05:58 PM
deedub711
Apr 19, 2011 09:11 PM
dgh91
May 27, 2009 07:53 PM
