-   -   Tip on Replacing the Front Tranny Oil Seal (https://blazerforum.com/forum/engine-transmission-35/tip-replacing-front-tranny-oil-seal-60163/)
freddyjones39 Jun 16, 2011 10:03 PM
So I had to replace the front oil seal on my '91 Blazer. After the long time it took to get it out, getting a new one in didn't look promising, but I found a method that helped A LOT!
All I did was put the seal in the freezer over night. I also froze a bowl of water to keep it cool as I tried to install it. The cooler temperature seemed to shrink it enough that it went in in just a couple of minutes. That is not to say it just slipped right in, but it was just a couple of tries and WAMO! I'll bet it also resulted in less damage to the seal than pounding on it with a pipe or something.
Hope it works for everybody else!
