Torque Converter disengages/engages after decline
I have a fairly hilly route that I take to work everyday. On the hill inclines, the truck will increase throttle to keep speed when the cruise is set (normal) and then pull the throttle out to coast down on the back side of the hill when it begins to decline to not exceed the set cruise speed. This is normal and expected with the cruise set. The problem is that, the torque converter will disengage/reengage in the valleys when the truck senses that the decline is over and throttle needs to be applied again. The cruise pulls the throttle completely out and the truck coasts down the hill. If I just keep my foot on the throttle going down the hill, the torque converter stays locked when the cruise gives more throttle to go up the next hill. These are not steep inclines, just hilly enough to coast and then go into the next hill where throttle needs to be applied quickly. Gets into this heavy throttle and then coast sequence.
Is this normal? Is this going to shorten the life of my TC? Is there anyway to reprogram the computer to limit throttle position to keep it from coasting down the hills and then reengaging the throttle so harshly?
1997 GMC Jimmy 4 door 122k miles
Can also be an engine performance problem (lack of power) or brakes dragging - causing throttle to increase too much and TC to kick out. But yes, a lot of this is normal. They went to carbon fiber friction material because there is always some slip (variable) in the TC in the later 4L60e with E3. Never completely locks up. I wouldn't sweat it unless the trans is getting hot.
rviolette84
Dec 21, 2012 12:25 AM
