torque converter question
Old Jun 24, 2019 | 02:38 PM
kaymb's Avatar
kaymb is on a distinguished road
Default torque converter question
This is a 1991 Chevy blazer. I'm missing what I'm assuming is a drain plug on my torque converter. In the middle theres a hole. Is there supposed to be a bolt there as well that's missing? Also how do I refill the fluid that's drained?
Old Jun 24, 2019 | 07:16 PM
That's just a cover. The hole is there for drainage. If you pull that cover off, you'll see the torque converter.
Old Jun 25, 2019 | 09:47 AM
kaymb's Avatar
Ok okay. What about the first hole that looks like it's missing a bolt? Is that also for drainage or is that supposed to be plugged? Theres still plenty of transmission fluid when I checked, but this has 4 wheel drive and some fluid has leaked out. not sure if it's due to this or not.
Old Jun 25, 2019 | 09:49 AM
The other hole is for a strut rod that bolts from there to the motor mount on some applications. No need to plug it.
Old Jun 25, 2019 | 09:55 AM
kaymb's Avatar
Alright, thank you for the info. I appreciate it.
Old Jun 25, 2019 | 09:56 AM
Any time. That's what this place is for.
blanx
Jan 29, 2014 12:04 PM
blueblazer1969
Jan 20, 2013 05:17 PM
the_boz
Aug 5, 2011 11:03 AM
brandon1029
Feb 22, 2011 05:51 PM
nineteensixtycaddy
Aug 23, 2009 02:47 PM
