Tranmission issue: 2-3 shift is slipping
Old Oct 2, 2009 | 11:11 AM
JimmyBlaze's Avatar
JimmyBlaze is on a distinguished road
Default Tranmission issue: 2-3 shift is slipping
My transmission is acting a bit oddly. I seem to be getting some slip in the transmission during shifts when I am applying 50%+ throttle. At low speeds it won't slip, nor does it have any problem shifting in any other gears at any other speed. If I apply full throttle for a passing maneuver it will occasionally do the same thing.
So do you think I need a rebuild, or does it sound electrical? I just had the transmission fluid changed a few weeks ago which didn't make an appreciable difference.
Thanks for the input!
Pics for clicks!
Old Oct 5, 2009 | 11:17 AM
JimmyBlaze's Avatar
No advice/recommendations?
Alright then...
Old Oct 5, 2009 | 11:26 AM
Transmission problems are very hard to diagnose over the internet. There are some obvious problems that seem to crop up on the 4L60E, but slipping is generally caused by a lack of line pressure. Without knowing the actual line pressure you have, no one can really help. You need to get it to a mechanic familiar with the 4L60E transmission and its diagnosis.
Old Oct 5, 2009 | 11:44 AM
JimmyBlaze's Avatar
Excellent. I appreciate your reply.
I just wanted to get some troubleshooting ideas before taking it to the very expensive tech.
Thanks!
BlazerBum
Jul 28, 2011 07:45 PM
jaxgent
Mar 13, 2011 10:41 PM
kikeleal
Dec 16, 2010 07:46 PM
udeluz
May 26, 2009 08:45 PM
LT1KICKER
May 17, 2006 02:34 PM
