tranny
Old Apr 5, 2008 | 12:12 PM
waldon005's Avatar
waldon005 is an unknown quantity at this point
Default tranny
Yup you guessed it. 4l60e strikes again. i think this problem is a little different than the rest of them though. I have every single gear except reverse. Every foreward gearworks perfectly in 2 and 4 wheel drive. i put it in reverse and nothing. Do you guys have any clue what could be going on here. I have searched and i cant find anything that says something about losing just reverse.
Old Apr 5, 2008 | 01:56 PM
xmradioguy's Avatar
xmradioguy is an unknown quantity at this point
Default RE: tranny
You probably broke the sunshell very common and results in loss of reverse, also you likely don't have all your forward gears either.
There has been 2 upgrades made for the sunshell the latest is called the beast and is about $50 and will not break.
Old Apr 5, 2008 | 09:35 PM
WolfPack's Avatar
Default RE: tranny
Doesn't that $50 part still run upwards of $1000 since you still need a tranny rebuild?
Old Apr 6, 2008 | 08:31 AM
waldon005's Avatar
Default RE: tranny
I did have only 1, 2, and d in this blazer. I ran the codes on it and it said shift solenoid b was bad. I dropped the pan and replaced the solenoid. now i have all foreward gears. the only gear that i do not have is reverse. why would reverse go out and all foreward gears work? there is no code, there is not any other problem with this blazer anywhere except for the reverse not working. everything and i mean everything works perfectly. There are no noise now odd shimmies no shakes no nothing this blazer just doesnt have reverse.
Old Apr 6, 2008 | 05:01 PM
Default RE: tranny
Here is a generic 4L60E diagnostic check list for a No Reverse condition:
Old Apr 7, 2008 | 12:03 AM
waldon005's Avatar
Default RE: tranny
some asked what yeat this is and its a 95 lt 4 door 4x4.
Old Apr 7, 2008 | 06:47 AM
Default RE: tranny
I had asked, but then figured since you stated it was a 4L60E it really didn't matter. Check out the items listed in the table I posted above and let us know.
ski.dive
Feb 7, 2014 05:18 AM
bouser
Dec 10, 2009 11:46 PM
(SWE)Anders
Nov 2, 2009 05:52 PM
nine5blazer
Oct 18, 2005 05:19 AM
blazin97
Sep 14, 2005 08:23 PM
