-   -   tranny 911..... (https://blazerforum.com/forum/engine-transmission-35/tranny-911-a-69567/)
warthogdriver Apr 1, 2012 02:49 PM
tranny 911.....
ok....sorry didnt search for along time..kinda in a rush to find a ride to borrow.
short of it....was going down the road...stopped at intersection...noticed rpms jump slightly...sat waited for light and...NO GO!!!
i tried to engage front axle to move...axle will engage, no power though...fluid is good...no burn smell.
cable moves freely and i can see it shift at the tranny.
i am guessing i blew tranny finally.
so i need to find one to swap in asap while i find funds to rebuild old one over summer.
am i wrong? any thing else it could be?
there are no codes or ses lights...4x moves thru all stages.
driveshaft feels tight when i try to rotate by hand.
any advice would be great....preparing for the worse
thanks guys.
xgiovannix12 Apr 1, 2012 02:51 PM
have you tryed all the other gears ??
like 1st or 2nd? or regular drive ? depends what you have ...
warthogdriver Apr 1, 2012 03:02 PM
I went thru all gears. And 4x combos trying to move it.
no power to the wheels front or back.
i can hear front axle engage and transcase shift....just no power to wheels.
Never made any grinding noises either....just sounded like it dropped into nuetral and stayed there.
I had it in first with wife behind wheel letting it idle and i could push it backwards...
Rottidog Apr 1, 2012 03:04 PM
What about the wiring going to the shift solenoids & or fuses? Might be the torque converter. I know when my trans cooler blew a line off it was sluggish while I crept off the road with the TC pumping fluid out the line & all over.
swartlkk Apr 1, 2012 03:06 PM
Have you verified that the shift cable is still connected? Does it go into park properly?
Rottidog Apr 1, 2012 03:09 PM
Yeah no noise or grinding & a sudden loss of power when at idle doesn't seem to be internal, mechanical issue. Unless a or some seals suddenly popped.
Is the trans controled by the PCM or BCM? Something that sudden & noiseless screams electrical to me. It IS a 4L60E afterall
warthogdriver Apr 1, 2012 03:18 PM
Yes..i had wife shift cable while i watched and checked for movement on it.
no....i did not check fuses...forgot about electronic side of it
how can u checl torque converter?
Rottidog Apr 1, 2012 03:24 PM
Not too sure on checking the TC but 1 way to see if it's pumping is to take off the trans cooler line leading to the rad, put the end in a bucket, start the truck & put it in neutral or in D. It should pump fluid out.
warthogdriver Apr 1, 2012 03:35 PM
Ok....i had to get wifes jeep to get kids....will go back and check fuses and wiring....with fingers crossed.
Thanks for the advice so far....i will report back soon as i can.
totally forgot elec angle of the issue.
Rottidog Apr 1, 2012 03:35 PM
GL Jarad!
