tranny 911.....
Old Apr 2, 2012 | 08:46 PM
  #21
xgiovannix12's Avatar
Best to change the Converter seal and the rear tail shaft seal
you can use black rtv to seal the transfer case to the tailshaft Unless ya wanna go to the dealer for the gasket ... but rtv works just as fine
and yea might as well change the pan gasket and filter while your at it
Old Apr 3, 2012 | 09:45 AM
  #22
Rottidog's Avatar
Try calling a local trans shop & ask what they do or use for that trans to transfer case gasket.
Old Apr 3, 2012 | 12:33 PM
  #23
volfan4's Avatar
volfan4 is an unknown quantity at this point
Just had mine rebuilt and installed by a transmission shop and they used black RTV.
Old Apr 3, 2012 | 07:37 PM
  #24
warthogdriver's Avatar
Well.....update time.
i have the tranny...transcase...and all goodies out.
I did the end seals on both....i did rear main seal..all though it was fine.
I do however have a rear leak..it is the very back of the oil pan.
i am sure i know the answer but here we go...is there anyway to clean it up and use black rtv on the spot without dropping the oil pan??
Old Apr 3, 2012 | 08:00 PM
  #25
I dont think you need rtv on the oil pan the gasket should seal it just fine
you can use rtv to seal between the tail of the trans and the tcase tho
Old Apr 3, 2012 | 08:07 PM
  #26
Thats just it...i was trying to cheat and not drop the oil pan....it is fine everywhere else...just this one small spot at the rea of oil pan.
Old Apr 3, 2012 | 08:08 PM
  #27
oh the rear of the pan is leaking ?
Old Apr 3, 2012 | 08:12 PM
  #28
Yes...a small spot. Right under rear main seal....thats why i got the rear main done as well.
We are on way home right now...i am uploading pics right now.
edit pics.....
now mind you that rear seal in the pics is the stock one....230k and it looked good!!
leak is right below it on pan seal.
Old Apr 3, 2012 | 08:50 PM
  #29
Lol im sorry wart Its either im blind ... I dont see the pan or the leak
i do see a little fluid what looks like where the converter sits
Old Apr 3, 2012 | 09:16 PM
  #30
right in the red circle...directly below the main rear seal.
i have had a wet bottom directly under there for some time...never really leaves any drops..just always damp. i have cleaned the bottom of engine and it always comes back...it is a very slow seepage i guess...rather than a leak...just figured since i was in this deep i would do what i could
thank you for all the help to gio.
