Tranny Issues
Old Sep 14, 2011 | 10:36 AM
sctysct's Avatar
sctysct is on a distinguished road
Default Tranny Issues
Hello! I am new here and need some help. I just purchased a 92 s10 blazer for $500. 4.3 TBI. Speedometer and odometer do not work, but my real problem is no second gear. The vehicle has to get to a certain speed and will shift from 1 to 3 and then OD. Manual shifting does not do a thing for second gear. Oh! it's a 4L60E. Could it be a computer problem? or shift solenoid? or maybe the VSS? I dropped the pan and did a filter and fluid change for the hell of it but no change. Fluid looked muddy but no metal on the magnet. HELP!
Old Sep 14, 2011 | 12:58 PM
A VSS problem typically will lock the transmission in 1st so the fact that it has 3rd & 4th is somewhat baffling unless the early system handled things differently.
You can test the VSS much like any other speed sensor. It should produce >250mV-AC when the rear driveshaft is spun. If that checks out ok, then you need to start working your way back to the DRAC module, testing the wiring from the sensor to the DRAC first.
Old Sep 15, 2011 | 12:18 PM
sctysct's Avatar
Default Thanks swartllk
Thanks, I will test the VSS. I also tried the "paper clip" method and could pull no codes...
Old Sep 22, 2011 | 01:45 AM
hardyboy's Avatar
hardyboy is on a distinguished road
92 should have the 700r4 the 4l60e came more popular for blazer in 95 with the new body style they look the same but 4l60e has more wires running to it
ski.dive
Feb 7, 2014 05:18 AM
Joes95Blazer
May 20, 2009 03:34 PM
amp88fan
Sep 15, 2008 08:16 PM
wildcatxcr8
Jun 23, 2006 09:36 PM
getblazed00
Dec 19, 2005 03:44 PM
