tranny removal
Old May 26, 2008 | 07:03 PM
robtoy_r's Avatar
robtoy_r is an unknown quantity at this point
Default tranny removal
anyone have a good step by step how to on removing the tranny out of a 95 blazer
Old May 27, 2008 | 04:03 AM
blazin97's Avatar
blazin97 is on a distinguished road
Default RE: tranny removal
depends on if its 4x4.
If its 2wd: Pull the shifter cable, jack up the middle of the trans and pull out trans crossmember(4-13mm bolts with4-15mm nuts on bolts)and pull the 4 11mm bolts at the rear end and pull the driveshaft our(alot of trans fluid will spill out so but an oil cetch). 3 torque converter bolts(dont remember the size, I've had a 5sp for 4 yrs). Lower the rear of the trans and get a bout 2-3ft extentions with 6or8-14mm engine to trans bolts, then lower her down.
If 4x4 same thing but leave the rear drive shaft in but pull the front one. Pull 6-14?mm bolts out of trans to transfercase then start with the rest.
Old May 27, 2008 | 01:19 PM
robtoy_r's Avatar
yea it is a 4wd. so i leave in the rear drive shaft? but take out the front one. how am i supposed to get it out with the drive shaft still in there
Old May 27, 2008 | 02:27 PM
Hanr3's Avatar
I did a write up on it in teh Do It yourself section, although I am hearing that those threads have some sort of szie limit. I haven't looked at the thread so I dont know whats missing, if anything.
If your removing the tranny, all driveshafts have to come out.
dbrackett
May 27, 2010 07:34 AM
bob_elder
Mar 26, 2010 01:41 PM
Beauhawk
Apr 13, 2009 12:36 PM
