Tranny shifts hard when at operating temp.
You did no that they make an updated LOCK-UP SOLENOID anti-bleed design , also known as anti drain back - which keeps your converter charged with fluid when not is use? I have seen them on Ebay. Hope this helps? Sounds Like you have a Handle on this Problem. Keep us Informed. Thanks for your thread on this Matter.
So, what i recently found out was that if you clear the code and drive it in drive and leave it out of OD the code doesn't come up and the light stays off b/c the torque convertor is not slipping. we drove it about 100 miles in drive and the code never came back up, but when we put it in OD the code was pending then on the next trip it came back up. So if you are having this problem i recommend not using overdrive if you are having this problem. It will eventually cause damage if left un repaired. So, i have ordered the lock up solenoid and i'm waiting for it to come. I will keep everyone posted.
kstrange
Jun 6, 2011 06:56 PM
ColoNico.
Aug 4, 2010 09:09 AM
