Tranny solenoid
Old Jan 3, 2016 | 08:35 PM
user 1016's Avatar
user 1016 has a spectacular aura aboutuser 1016 has a spectacular aura about
Default Tranny solenoid
Does anyone have a diagram or specific part number for the solenoids for a 2000 blazer. Specifically the lock up 1-2 solenoid? Auto zone and other stores have two options, and for the life of me, I can't figure out for sure which one goes where. I don't want to spend $30 some dollars to have the wrong part. Also, anyone know what they are supposed to ohm out at? The 4 "corners" tested out at 20, 20, 20, and 9. From what info I can find, this might be normal?
Old Jan 5, 2016 | 06:06 PM
slimsummers's Avatar
slimsummers is on a distinguished road
What is a "lock up 1-2 solenoid? The 4L60E transmission has two identical shift solenoids at the rear, sometimes called the A and B solenoid, or 1-2 and 3-4 solenoids. There is a Pressure Control Solenoid just forward of that on the side of the valve body. Up front you have the lockup on-off solenoid mounted into the bottom of the pump with two small bolts, and two similar looking solenoids mounted in the front of the valve body. One is the pressure control for the lockup, or Lockup PWM solenoid, and the other is the 3-2 downshift solenoid.
Corners of what?
Tony H
Jan 21, 2011 10:11 AM
Tony H
Feb 23, 2010 08:09 AM
god_zilla00000
14
Jan 5, 2010 05:26 AM
Recycler
May 20, 2006 02:31 PM
MWRIGHT252
Engine & Internal
Jun 14, 2004 03:01 PM
