Tranny swap
Old Feb 11, 2019 | 06:00 PM
1997chevblazer's Avatar
1997chevblazer is on a distinguished road
Default Tranny swap
Hello I have a 1997 4wd blazer the tranny went out now it only has 3rd and reverse if The tranny fuse is pulled. I have a 1997 gmc 1500 4wd with a good tranny and a bad frame. Is it possible I can swap the tranny from the gmc truck into my 97 blazer? Any help would be great thanks!
Old Feb 11, 2019 | 06:25 PM
cleburne red's Avatar
If they're both 4L60E, then it should work. Might have to change t cases maybe? Think the full size is different. Could be wrong, I'm talking outta my rear end lol
Old Feb 11, 2019 | 09:46 PM
i do believe their both the 4L60e I’m not sure about the t case the blazer is push button 4wd and the gmc is manual 4wd
Old Feb 12, 2019 | 04:46 AM
Transman304's Avatar
Same transmission no difference in them other than the stall on torque converter which won’t be noticed. Plug and play. I assume the 1500 has a V8? Be sure to flush the cooler lines and cooler before installing replacement transmission. Good luck
Brad
Old Feb 12, 2019 | 10:09 AM
Thank you!!
1997chevblazer
Mar 30, 2018 03:50 AM
gpaholsky10
Jul 4, 2009 12:10 AM
RicanGSXRDude
Oct 3, 2008 06:07 AM
MusicMaverick
Jan 26, 2006 03:27 PM
blazin97
Sep 14, 2005 08:23 PM
