Trans dosent down shift
Old Feb 17, 2020 | 10:05 PM
Vincent01's Avatar
Vincent01 is on a distinguished road
Default Trans dosent down shift
I have a 1999 Chevy blazer and it runs good it has 224,000 miles on original motor and trans. But the lady I bought it from over filled the trans a lot. Like a ton. So with my oil dipstick pump I pumped out some fluid. But it still has this problem where when it gets hot after about 40 mins of driving it dosent down shift from 3rd. I can manually shift it into first and then to drive and it’s fine. I have a U1193, U1192, U1042, U1026 codes I want to see if it’s something simple before I pull the trans and rebuild it
Old Feb 18, 2020 | 07:17 PM
Transman304's Avatar
Welcome to the forum,
With the U codes you have listed I would lean towards that the PCM is losing power at some point. It takes a millisecond for the PCM to set these codes when signal is lost. Do the lights for the shift indicator in the dash work?
Brad
68Datsun510
Jul 19, 2012 08:35 AM
TheRandom1
May 5, 2011 11:17 PM
eight hundred dollar blazer
Mar 18, 2011 05:21 AM
SteveFebreze01jimmy
Apr 15, 2010 09:48 AM
CEThomas
Apr 28, 2009 07:33 AM
