Trans fluid leak from radiator?
Old Aug 10, 2014 | 01:04 PM
Trillavicious's Avatar
Trillavicious is on a distinguished road
Default Trans fluid leak from radiator?
I have a 98 Chevy blazer the trans fluid has been leaking out of the front passenger side I've been filling it up now it has trouble shifting do I need a new trans or just replace the radiator the lines tranny filter and flush?
Old Aug 11, 2014 | 12:38 AM
AJBert's Avatar
Check the fittings going into and out of the radiator. Sounds to me like that is where your leak is coming from.
If you have oil in the coolant, then that is a different problem and you will need to replace the radiator.
Old Aug 15, 2014 | 02:28 PM
Tajohns34's Avatar
the fitting part number for Dorman is 800-605. They are cheap and easy to replace.
razman
Dec 30, 2014 10:14 PM
iamchevyman5
Sep 22, 2012 05:59 PM
luthers97blazer
Nov 10, 2008 01:27 PM
pbrew
Apr 30, 2008 12:11 AM
harleybob
Nov 10, 2007 07:25 PM
