trans issues need advice
Old Sep 15, 2017 | 10:17 PM
hype56's Avatar
hype56 is on a distinguished road
Default trans issues need advice
95 blazer 4x4 lt. Doesn't want to go in gear. Trans fluid good. When put in drive, pedal down doesn't want to move, but does slowly. Pulled drives haft out, dirty fluid and metal pieces came out. Trying to pull trans out, but found out that 95 blazer trans one of kind. Any advice?
Old Sep 15, 2017 | 10:37 PM
AJBert's Avatar
My bet is the sunshell is toast. Plan on a rebuild or reman. I'm not even close to being an expert on transmissions but when you find metal it is toast.
Old Sep 17, 2017 | 06:22 AM
ChuckNTruck's Avatar
You say you pulled the driveshafts out and dirty fluid / metal pieces came out?
Did those pieces and bad fluid come out of the transfer case?
Old Sep 19, 2017 | 06:40 PM
AJBert's Avatar
Nice catch, I wasn't even thinking of that.
Old Sep 24, 2017 | 12:28 PM
Sounds like what happened to my truck. The clutches were burned out and slipping. Had to have it rebuilt. I definitely was at fault for doing a lot of towing with it. I now have a temperature gauge installed to monitor the transmission fluid temperature.
Good Luck,
Christine
Old Sep 28, 2017 | 03:25 AM
Shouldn't a 1995 still have a 4L60E?
drummerdude84
Jan 29, 2012 09:54 PM
android1021
Nov 26, 2011 05:58 PM
smg614
Jun 21, 2011 12:13 PM
Ape357
Jan 8, 2011 07:53 PM
Ape357
Jan 7, 2011 01:28 PM
