Trans Linkage Issue
Old Dec 30, 2007 | 03:20 PM
85v8blazer's Avatar
85v8blazer is an unknown quantity at this point
Default Trans Linkage Issue
I just recently bought an 85 s10 blazer that has already been converted into a V8 with a 700r4 tranny.. The main problem is no matter what gear I shift the lever into the trans stays into what seems to be neutral. No matter what gear it will roll freely. Any suggestions I will gladly accept.
Old Dec 30, 2007 | 04:16 PM
Chevy Lover's Avatar
Default RE: Trans Linkage Issue
Have you checked the trans oil level and have you checked that the shifter shaft on the trans actually moves when you move the shift lever inside the truck.
If these are both ok, then it's possible something has come loose inside the transmission and you'll probably have to remove the pan to have a look.
Old Dec 30, 2007 | 09:47 PM
85v8blazer's Avatar
The fluid is fine but thats as far as I have gotten so far.. I just bought it a few days ago and its been raining everyday since so no real chance to get underneath it. I was just trying to get a few starting points. Thanks
Old Dec 30, 2007 | 09:54 PM
Blazin_Jason's Avatar
Yeah like CL said, check the bolt that holds the rod tight. It may have become loose and won't shift the tranny. Where you located?
Old Dec 30, 2007 | 10:28 PM
85v8blazer's Avatar
I will check that tomorrow. I am located in Georgia. That is just the first problem I have come across. I am expecting a few more but I knew it was a project the price was right and I have always wanted a V8 conversion s10 blazer so I couldn't pass it up
Old Dec 30, 2007 | 10:46 PM
Cool post up some pics sometime. Were you able to test drive it, or was it purchased with some work needed? Are you familar with the 700r4 trans? Hopefully the TV cable is setup properly.
Old Dec 30, 2007 | 11:01 PM
85v8blazer's Avatar
I wasn't able to test drive it, 2 flats and no spares but I knew it needed some work. I heard the engine run and that sold me on it. Very good running so its worth the work.. I will post pics tomorrow just kinda hard to take them in the rain lol. I know nothing about the tv cable never messed with a 700r4. Any tips for me?
Old Dec 30, 2007 | 11:12 PM
Was it being driven before? The TV cable is very important in these trans. It lets the trans know when to shift/down shift etc. It controls a valve in the trans to regulate pressure. I don't know too much either, but the TV cable is quite important. Maybe do a search about them. v8s10.org is also a good site for v8 trucks.
Old Dec 30, 2007 | 11:17 PM
85v8blazer's Avatar
it has been sitting for a few weeks but it was being driven before. But definitely thanks for the ideas to check out. I would like to get it up and running in the next few weeks.
Old Dec 31, 2007 | 08:44 PM
Hanr3's Avatar
keep posting information.
The more you post the better we can help you.
