Trans options for the 4l60e
Old Apr 23, 2013 | 01:16 PM
owendan's Avatar
owendan is on a distinguished road
Default Trans options for the 4l60e
First time posting, so be patient. I have a 2000 blazer 4x4, with the 4.3l v6 vortex. it has a blown 4l60e.... which by checking out your site is a crappy trans, so is there any other trans option that will line up in this truck like a 4l80e, and if not does anyone know what year span option i have when buying a new/used replacement trans...Thanks everyone
Old Apr 23, 2013 | 05:25 PM
Diaita's Avatar
There are no other transmissions that would simply bolt it. You could put a 4l80e in, but you would need to adapt to your transfer case, or install a different transfer case. And the ECU would also need to be programmed.
The 4L60E transmission is a good transmission, used in thousands, if not hundreds of thousands of vehicles. The main reason if not only reason they fail is due to lack of maintenance.
Old Apr 24, 2013 | 12:42 AM
LeWhite's Avatar
Some have a plastic foward apply piston and accumulator piston that can crack. And a EVA screen that can collapse. You can step up your game by installing a transgo kit and a slightly stronger 1-2 accum piston spring.
dj00140
22
Nov 4, 2015 05:03 AM
an240172
Sep 7, 2009 02:58 AM
Dakota_Don
Nov 18, 2008 10:42 PM
erobe387
Apr 27, 2008 06:12 PM
95blazer8620
Oct 19, 2007 01:26 PM
