Trans troubles - no overdrive.
Old Apr 14, 2011 | 11:45 AM
  #21
Originally Posted by kcub
Do you mean to , hook the ground of my test light to a positive and probe the DK BLU wire to see if it is grounding and un-grounding when the trans is shifted (with engine running)?
If you are using a test light, then yes. And you will have to back-probe the connection. You likely will not be able to have this connector unhooked while also having the engine running.
Old Apr 14, 2011 | 11:37 PM
  #22
kcub's Avatar
kcub is on a distinguished road
I checked for ground and got nothing. Will I have to drop the pan to check the range/ pressure switch, or can i check the wires at the PCM? Could there be a loose connection in the pan or is it more likely a bad switch?
Old Apr 18, 2011 | 09:11 AM
  #23
kcub's Avatar
I checked and have power at plug connecting to trans (pink wire). If it has power to switch , is there anything else that could cause it not to work. Other than a bad switch.
Old Apr 18, 2011 | 09:40 AM
  #24
In the case of D4, Channel A should read open (no continuity to ground) and channels B & C should read closed (continuity to ground). This is with the engine running and the shifter placed into the appropriate position. These values are best monitored with a capable scan tool.
If all of the wiring checks out from the ECU (under the dash) to the range/pressure switch, then the switch is the most likely culprit.
Old Jun 14, 2011 | 01:33 PM
  #25
kcub's Avatar
Default fixed finally.
Thanks to those that offered information and ideas. I finally went into the to check the pressure/range switch. i replaced the switch and wireing harness. Once together, shifted like a champ. Have all gears now. Now on to the next item on the list to fix.
Flatearthman
Jul 11, 2012 06:53 PM
Romper
Mar 23, 2011 05:55 PM
schreckman
Mar 20, 2009 09:27 AM
ironclad
Aug 18, 2008 04:05 PM
bblazer123
Jan 6, 2008 07:48 PM
