Trans will not shift?
Old Apr 19, 2009 | 07:11 PM
CEThomas's Avatar
CEThomas is on a distinguished road
Default Trans will not shift?
I just replaced the trans in my 99 Blazer with one out of a bone yard. Took it out for a test drive and it will not shift out of 1st. drop it down in 2 & 3 and it keeps in 1st Over the years I have got 4-5 transmissions from this bone yard and they have all been good, so when they told me that it was good when they pulled it I belive them. What could have went out during the time they pulled it and I put it in??? Also the trans fluid level it ok and all plugs are plugged in.
Also no codes were stored during after the drive..
Thanks,
Charles
Old Apr 21, 2009 | 07:53 PM
TomSawyer's Avatar
TomSawyer is on a distinguished road
Unhappy
I had the same problem with my transmission and it turned out to be the governor. However, my truck is a '91 with the 700r4 transmission, your truck has a different transmission, not sure which (4L60e?) which is basically the electronic version of what I have, I believe anyway. swartlkk help me with mine, he may be able to help you.
Old Apr 22, 2009 | 12:16 AM
bandidolenny's Avatar
A salvage yard will normally have a 30 day exchange policy. They should have stamped the new tranny with their punch-mark and given you a reciept. The only problem is you are gonna have to do all that labor again and hope you get a good one next time.
Old Apr 22, 2009 | 09:18 AM
Is the shift linkage adjusted properly? PCM reset? Does it just rev out with no indication of shifting? Any codes present when you scan the PCM?
Old Apr 28, 2009 | 07:33 AM
CEThomas's Avatar
Thanks,
It was a bad speed sensor..
Digitized
Jan 12, 2014 12:07 PM
bigdawgz2006
Nov 21, 2009 02:44 PM
riggermm
Nov 4, 2009 06:06 PM
Blahman20
Nov 3, 2008 09:45 PM
