Transfer case and front diff fluid change Question
Soon ill be flushing the radiator, changing the oil,changing the trans fluid, changing the fluid in the front and rear diff, and the transfercase.
Ive of course flushed a radiator, changed oil, and changed the trans fluid and filter.
Now this is my first 4x4 so ive never done a front diff or transfercase.
Any helpful imput?
Thanks, Brian
Any helpful imput?
Thanks, Brian
80w90 GL-5 or 75w90 Synthetic fluid for both the front and rear differentials.
As far as the transfer case goes:
- Dexron III ATF if you have the three button 4wd switch on the dash
- GM Autotrak II if you have the four button 4wd switch on the dash with Auto4wd option
BrinkDiamond
Mar 2, 2014 03:50 PM
Fullsizeon38s
Oct 17, 2013 06:49 PM
ComputerNerdBD
Jan 14, 2012 12:07 PM
DaleA
Jan 13, 2009 08:50 PM
