transmission
Old Nov 4, 2014 | 05:17 PM
94blazer68's Avatar
94blazer68 is on a distinguished road
Default transmission
My 94 full size blazer is having tranny problems. Need some help. When it shifts into overdrive the RPMs jump up a few hundred and drops back down. The tranny shifts fine no hard shifts or jerking. It does this if u ease on the gas. If you stomp it it shifts fine. Fluid levels are good. Any ideas what could cause this. Thanks for any help
Old Nov 5, 2014 | 01:56 AM
gtmccormick's Avatar
gtmccormick is on a distinguished road
You might what to check the vehicle speed sensor there also a black sensor up on the throttle body that helps control the shift can't remember the exact name
Old Jan 26, 2015 | 12:04 PM
rap's Avatar
rap
rap is on a distinguished road
Default Any Update
I am having a similar issue with the transmission in my 98 LT 4wd. Did you ever find the issue?
Thanks,
Richard
Old Jan 27, 2015 | 11:31 AM
No I ended up parking it till spring when I'm going to pull and replace the tranny because there so problem prone sorry I couldn't be more help if you figure it out I would love to know
Old Jan 28, 2015 | 06:29 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
They are actually very good transmissions and there are a few other things that can be checked. i would before I just randomly replaced the unit. Get the TPS checked first.
Old Jan 30, 2015 | 02:26 PM
Checked the tps…the shear number of problems posted here with that tranny shows there not the best I would take the old TH350 any day
Old Jan 30, 2015 | 03:26 PM
newguy's Avatar
Have to agree with gregg, they arent bad trans at all.
Old Jan 30, 2015 | 03:51 PM
Gregg64's Avatar
It basically is a 4 speed 350. now they are just electronic. Thats why they are called 4L60E's. A modern 400 is a 4L80E
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
