Transmission codes
Old Jun 4, 2022 | 09:20 PM
Hess13x's Avatar
Default Transmission codes
Ok I'm pretty sure I've got this figured out but thought I'd post it anyway and get some feedback. 97 blazer is in limp mode, starting off in 2nd gear and then only shifts to 3rd. No 1st and no overdrive. Here are the codes.
This comes and goes one day it shifts fine and the next its in limp mode. Im thinking bad or loose main trans connection. Or bad key switch. Also sometimes the key won't turn all the way back to lock position and I can't get the key out. Thoughts?
Old Jun 7, 2022 | 09:48 PM
Hess13x's Avatar
Ok so just incase any one goes looking for an answer. I figured it out. Bad ignition switch. I just jumped a power wire to the trans fuse until I get i changed out.
Old Jun 10, 2022 | 10:47 AM
LesMyer's Avatar
Thanks for posting the follow-up!
lancelot6840
Feb 25, 2014 06:31 PM
racsan
Apr 7, 2013 05:42 PM
Scarakus
Dec 20, 2012 04:27 PM
greenhornet
Apr 28, 2012 07:28 PM
whiteman_01
Sep 9, 2009 11:39 AM
