Transmission Disorder
Old Mar 8, 2015 | 09:12 PM
snuffy's Avatar
snuffy is on a distinguished road
Default Transmission Disorder
2001 Blazer 150k miles
First I would like to say I bought this knowing the trans was bad. I am not sure of too many details except that this is the second trans for this vehicle and it has about 75k miles on it.
I was going to use the car for parts but if I can fix it I will have a nice 4 wheel drive to use as a DD or whatever.
After I trailer-ed it home I tried to run it and after about 20 minutes it would loose all forward and rev movement.
I changed the fluid and filter.
The fluid did not have metal flakes in it and does not feel gritty. It does look kind of brown, kinda like clutch material.
This got the trans working again, but now there is a chatter/buck and some slipping when I get over 55mph at a steady cruise. I found a nice stretch of road to test this out. It does this in 3rd and 4th gear.
My guess is the 3-4 clutch pack is worn out.
Has anyone dared to go into the trans and rebuild? If so would you mind sharing your experience?
Thanks
Old Mar 11, 2015 | 01:11 PM
abig84's Avatar
i bought my 93 with the same issue, has all sorts of 3rd and 4th gear issues. since my truck is a off road only truck i just ignore those gears. 7 years later that trans is still working fine
Old Mar 11, 2015 | 06:32 PM
newguy's Avatar
I rebuilt mine myself not knowing anything about it. After searching youtube and other forums I had enough confidence to do it myself. Wasnt as hard as people think. The hardest part was getting it out. Took one day to rebuild and one day to reinstall. 7000 miles later its still going strong
Old Mar 12, 2015 | 03:35 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Make sure you get a new torque converter built for it. i would never re-use the old one. It has as much if not more crud in it as the trans did. And flush the lines and cooler too.
Old Mar 12, 2015 | 08:47 PM
snuffy's Avatar
That's cool, good to know these are tough transmissions. I really want this one to work correctly if possible.
Exactly what I wanted to hear, thank you. Glad it's still going strong. This gives me the confidence to take it on.
Yes I will definitely do this. I thought about reusing it as is but like you say all the old crap is still in there. I know of a place locally with a good reputation I can use.
Thank you everyone for your input.
Old May 25, 2015 | 07:16 PM
snuffy's Avatar
Default Update
OK so I'm a slow worker.
I decided the trans needs to come out and started the disassemble y. I removed as much as I could before removing the cross member. The stater was the hardest to get out, now I know how to do it, still a PIA but I found a little easier method.
A little more work and the trans will be out, and on to phase 2.
Attached Thumbnails Transmission Disorder-5-25-2015%2520blazer%2520pics%2520009_zpsjkldyldx.jpg   Transmission Disorder-5-25-2015%2520blazer%2520pics%2520008_zpsrqsskqap.jpg   Transmission Disorder-5-25-2015%2520blazer%2520pics%2520011_zpsfdrtgkyk.jpg
Old May 25, 2015 | 07:34 PM
newguy's Avatar
Glad your taking it on yourself. You can do it take your time
Old May 25, 2015 | 07:37 PM
snuffy's Avatar
Thanks, will do. I'll update as I get more done.
Old May 25, 2015 | 07:38 PM
newguy's Avatar
Old May 25, 2015 | 08:44 PM
snuffy's Avatar
Wow, thank you sir.
I may also have some questions along the way.
