Transmission Disorder
Do you remember what rebuild kit you used?
sorry cant think of it ,but if I remember I`ll let you know
So I am starting to put this thing back together. I get to the input housing and load all the clutch packs. To test the operation of the pistons you apply air in the feed holes in the shaft. When I applied air to this hole (3-4 clutch pack) the piston moves and the clutches engage but there is air blowing past the orifice cup plug in the housing, It's the hole in the housing to the right of my hand. I don't think there should air leaking past that cup plug, am I wrong?
Input housing
Air testing.
Input housing
Air testing.
