transmission help!!!!!!!!
Old Jul 20, 2012 | 06:47 PM
lityjohn701's Avatar
lityjohn701 is on a distinguished road
Default transmission help!!!!!!!!
I have a 1998 blazer 4wd and i have a 1998 s10 transmission 2wd will this work? will the 4wd still work?
Old Jul 21, 2012 | 11:00 AM
jaked up's Avatar
jaked up is on a distinguished road
the 4wd is in the t-case i think the 4x4 trans are more heavy duty but im not shur on that and idk if the tail shaft is different or not
Old Jul 21, 2012 | 11:06 AM
In order to turn a 2wd transmission into a 4wd transmission, the tail shaft must be swapped. This requires the complete gutting of the transmission and is not for the first timer to attempt. Other than that there are no other differences.
Old Jul 27, 2012 | 04:52 PM
it looks like the tail shaft can come off then should bolt directly to the t case?
Old Jul 27, 2012 | 10:59 PM
cucv30's Avatar
cucv30 is on a distinguished road
Yeah they can be swapped but they both have to be torn down at least to the front planet set to remove the snap ring holding it to the output shaft.
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
chris24301
Nov 21, 2006 05:11 PM
1badSRAD
Sep 14, 2006 04:31 AM
goken50
Feb 13, 2006 04:35 PM
