transmission help needed
Old Sep 17, 2009 | 03:00 PM
hotrod413's Avatar
hotrod413 is on a distinguished road
Default transmission help needed
I was driving to the junkyard, when my truck shifted into neutral. It was still in D but when I rev'd it, it went nowhere. I stopped and checked the fluid, which was a quart low, refilled it, but still nothing......Still isnt moving. I got a tow home, and had to damn near floor it to get it into the garage. I took the pan off, since I bought a new gasket and filter anyways......Is that how the fluid is supposed to look? Isnt it supposed to be pink? There is no sediment or metal shavings, so there is still hope, right?
What should I look for under the tranny since the pan is already off? It had the 1-2 shift issue, but still worked....I NEED HELP!!!! What can cause this?!?!?!
EDIT: I went ahead and put the new filter on, and refilled with fluid. I used dexIII and she still isnt working. Its doing the same thing as before....there is a buzzing/ rattling noise coming from the front of the tranny/back of the engine, when in drive, and reverse, but quiets when in park.....could this be a bad pump?
wallacereid
Jan 9, 2012 12:34 PM
bigdaddykane93
Jan 11, 2011 03:55 PM
Mr.T
Nov 2, 2010 08:49 AM
bigdaddykane93
Aug 21, 2010 02:06 AM
