Transmission issues
Old Dec 23, 2018 | 09:52 AM
Randyerwin16's Avatar
Randyerwin16 is on a distinguished road
Default Transmission issues
Hello I'm new to the group I have a 1994 blazer 5.7 four wheel drive about a week ago out of nowhere pulling in to my driveway I had to give it more gas to get up the little hill and realized I had no first gear so I checked the transmission fluid and it was good hot and cold so I took it to my mechanic put it on the computer said that I had some solenoids were bad in the transmission so what I really would like to know if I should replace the Solenoids or just get new transmission
Old Dec 23, 2018 | 10:49 AM
cleburne red's Avatar
Not much of a transmission guy, but what is the cost of solenoid replacement vs replacing the trans? Solenoid is bound to be way cheaper.
Also, how many miles are on it? Was the trans having any issues prior to this?
If the solenoids can be done with the trans still in place, I would do that. Anything that requires pulling the trans out, imo might as well rebuild it while it's out, especially with a 24 year old truck
Old Dec 23, 2018 | 11:26 AM
Thanks I was leaning toward changing the solenoids The transmission of been done a year before I bought it which was like two years ago and no I never had an issue whatsoever with the transmission no problems at all until that day last week check the transmission fluid no burnt smell it was good color no leakage
Old Dec 23, 2018 | 12:28 PM
If the transmission has been gone through just a couple years ago, definitely just do the solenoids.
On the other hand, if it's just been done, why are solenoids going bad already?
Old Dec 23, 2018 | 12:44 PM
Rite I'll know more about it after Christmas will let you know thanks for the input
Old Dec 23, 2018 | 12:57 PM
No problem man! Good luck.
Maybe the solenoids just weren't changed out before? Pretty sure that's all done in the pan, and relatively easy to do.
Old Dec 23, 2018 | 02:32 PM
odat's Avatar
My bet they are the org and not changed out during the rebuild, cheap rebuild too cut costs and get it in and out the door
Old Dec 23, 2018 | 03:04 PM
newguy's Avatar
solenoids are easy to change, drain the fluid, take the pan off, pull the filter off and they`ll be right in front off you. Very easy job
Old Jan 9, 2019 | 08:16 PM
Ok so meant to tell y'all transmission issue was burnt wires so that was taken care of she is running like a champ thanks for the info
Old Jan 9, 2019 | 08:48 PM
Hey, thanks for the update, man It's always nice to have closure to a thread!
