Transmission Leak next to trans dipstick??
Old Nov 5, 2013 | 10:30 PM
GMC_Jimmy_13's Avatar
GMC_Jimmy_13 is on a distinguished road
Exclamation Transmission Leak next to trans dipstick??
Here is the pic of the stem next to the transmission dipstick which is leaking. It also seems to be leaking transmission fluid underneath that I am thinking is coming from the pan with the filter inside. But why would it leak from up above next to the dipstick like that? Anybody? [IMG][/IMG]
Attached Thumbnails Transmission Leak next to trans dipstick??-photo_zps3c96a7df.jpg
Old Nov 6, 2013 | 03:46 AM
Chevy33's Avatar
Chevy33 is on a distinguished road
Default That there thing
That is a vent tube. No fluid should be coming out that there tube. I bet ya got some tubes out of place or ya got a blocked drain tube.
Old Nov 6, 2013 | 03:59 PM
KM346's Avatar
KM346 will become famous soon enough
Sounds like a classic T-case input seal failure... When they fail the transfer case will slowly fill with transmission fluid, overfilling it to the point of pushing it out that vent tube.
Pull the top (fill) plug on the back of the transfer case. If fluid pours out you have found the problem. Make sure you have a drain pan ready...
razman
Dec 30, 2014 10:14 PM
fox440
Oct 31, 2011 09:23 PM
chipjumper
Oct 27, 2010 09:31 AM
Cobra102000
Sep 29, 2010 10:25 PM
fruggy
26
Apr 28, 2010 08:18 PM
