Transmission lines, flow direction?
Old Mar 7, 2009 | 04:50 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Default Transmission lines, flow direction?
on a 96' 4l60e which line is IN and which line is OUT in respect to the trans, i get confused. let me know please.
Old Mar 7, 2009 | 09:11 AM
Taymacjack's Avatar
I dont know which is which but i can show you which line goes where.
Old Mar 7, 2009 | 02:14 PM
Apreciate the help but I already know which line goes where.
I just need to know which is IN and which is OUT.
Old Mar 7, 2009 | 08:09 PM
Originally Posted by swartlkk
As some other threads state, the upper line is the line from the transmission with the lower line being the return to the transmission. On my Bravada, I used the upper line out of sheer convenience and the temps even in the summer with a fully stacked straw wagon behind it, it kept the transmission in the 180*F to 195*F range. The cooler in the radiator is an effective cooler, why take it out of the loop?
That should answer your questions.
Old Mar 7, 2009 | 09:49 PM
Booyah, thanks kyle, you are allways on it!
Old Mar 7, 2009 | 10:06 PM
Uh... Spoke to soon. Now Im really confused.
700R4/4L60/4L60E/4L65E
Fitting Location Thread Size Flow Direction
Upper ¼" Pipe Return/in
Lower ¼" Pipe Cooler feed/out
Also http://www.txchange.com/cooler.htm
Let me explaine... Somebody mucked with my truck before it was mine... I had a buddy replace the trans ghetto style... My rad cooler was bypassed... and I am trying to put it back together the right way... what i want is to do this...
transmission>>rad-cooler>>ext-cooler>>ext-filter>>transmission
thing is... the way it is now, i believe the lower line is pushing the fluid. just trying to get my head on straight!
Old Mar 8, 2009 | 09:31 AM
The differences noted in the further information you find lie in where you are looking. I was speaking of the factory connections at the radiator while your references seem to be speaking of the lines on the transmission...
mitchell27
Feb 9, 2021 08:49 AM
stevemoble
Jan 2, 2008 06:03 PM
RMassa187
Dec 16, 2007 01:06 AM
thisjrocks
Lifting Tech
Aug 14, 2007 01:34 AM
eslhockey92g
Tires and Wheels
Apr 28, 2007 06:11 PM
