transmission and overdrive......
Old Dec 11, 2008 | 06:14 AM
wetdog's Avatar
wetdog is an unknown quantity at this point
Default transmission and overdrive......
.......hi guys,
my previous 4x4's have all had an overdrive. with a button on the lever to override it and a light on the dash to confirm this, on/off for towing etc.
my blazer doesnt have this. so my question is, what gears does my tranny have?
i thank you,
mick.
Old Dec 11, 2008 | 04:13 PM
Hanr3's Avatar
Default RE: transmission and overdrive......
Your '00 S10-Blazer has the 4L60E tranny. This tranny ahs overdrive and 4 forward gears. 4th gear is overdrive. If you dont want to use od, use 3rd gear. 3rd gear is a 1:1 ratio gear. And 3rd gear is recommended if your towing, especially if your tranny is hunting for a gear.
your tranny also has a lock up torque converter.
Your column shifter will either show
R, N, 1, 2, 3, D or
R, N, 1, 2, D, OD
D in teh first example is Overdrive
OD in the second example is OverDrive.
Both are 4th gear.
Old Dec 12, 2008 | 06:03 AM
wetdog's Avatar
thank you,
mick.
Old Dec 13, 2008 | 09:30 AM
Hanr3's Avatar
Your welcome!
SoullessNihilist
15
Jul 18, 2014 08:22 AM
Romper
Mar 23, 2011 05:55 PM
kcaughro
Feb 1, 2010 09:10 PM
onecrazyfoo4u
Feb 15, 2009 07:42 PM
sickpuppy
Dec 29, 2007 02:04 PM
