Transmission problem
Old Dec 3, 2021 | 07:51 PM
papajim's Avatar
papajim is on a distinguished road
Default Transmission problem
I have a 99 blazer, 4.3 automatic. My reverse went out a few days ago, it has been driven very little the past few years. All the fwd gears work fine just no reverse. I bought some Lucas trans fluid thinking something was stuck from setting. I was told to drain some fluid out first. So I removed a cooler line from the radiator and let the engine run a few seconds, nothing came out, so I started the engine again and put it in reverse then drive but no fluid came out. What could be wrong, I have fwd gears and no line pressure to radiator, no reverse. Thanks for any help
Old Dec 5, 2021 | 10:56 AM
GeorgeLG's Avatar
I'm not much of a transmission guy but here is the no reverse diagnostic chart for my 2002
Besides the fact that most of us are not transmission guys, we are the additional disadvantage that most of us cannot read the proprietary GM ODBII codes that might narrow this down.
George
George
Old Dec 5, 2021 | 11:13 AM
GeorgeLG's Avatar
... and the chart for hi/low trans oil pressure:
George
Old Dec 6, 2021 | 09:16 AM
papajim's Avatar
George
I feel it is a simple fix but I know nothing about transmissions . It was rebuilt several years ago but has only 20k miles on it. It was built by Carolina transmission
I am thinking something is stuck from setting for some time.
Old Dec 6, 2021 | 10:24 AM
GeorgeLG's Avatar
You can check the wiring and supply voltage to the trans. I can’t be of much help beyond this, hopefully and person with more transmission experience will chime in to help you. Good luck,
George
Chevy33
Aug 30, 2011 05:22 PM
JBUNDY31
Aug 30, 2011 06:57 AM
chevygonzalez
Dec 2, 2010 06:08 AM
Experior
Nov 7, 2010 10:00 PM
BEENDIGGIN
Feb 15, 2007 11:01 PM
