Transmission Problem???
Old Oct 27, 2011 | 04:31 PM
johnnybjr's Avatar
johnnybjr is on a distinguished road
Default Transmission Problem???
I recently bought a '97 blazer for my daughter. I had to replace the gasket on the transmission pan and the filter. Now, it seems to be stuck in a high gear when you drive it. I can manually start out in 1st and get good acceleration, but not in Drive. Any suggestions? I don't have alot of exp with transmissions.
Old Oct 27, 2011 | 11:28 PM
trucktom's Avatar
trucktom is on a distinguished road
what gear does it take off in in D? did you wrestle the pan off too hard and break a shift solenoid in the back of the trans??? usually got to pull the crossmember to get the pan off
Old Oct 28, 2011 | 12:01 AM
chris015's Avatar
Sounds like maybe the filter fell into the pan. Did you get the old seal out that was on the old filter? sometimes they stay in the hole and when you put the new filter in they dont seat all the way.
DBo42098
Aug 25, 2009 05:11 PM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
Cuppy
Jul 21, 2006 11:25 PM
jermag24
Engine & Internal
Jan 6, 2005 10:56 PM
