Transmission Problem
Old Jan 24, 2017 | 08:27 AM
Hughesevan99's Avatar
Hughesevan99 is on a distinguished road
Default Transmission Problem
Ok Guys & Gals I Need Some Help I've Got A 1994 Chevy S10 Blazer 2 door with push button 4wd & a 4.3 liter Vortec Engine and it has no reverse all forward gears still function properly but i have no reverse and no neutral from neutral gear on down to 1st gear it goes forward and when u put it in reverse u can tell its in gear but it just freezes up & wont move at all under power but if u shut it off itll move forward and backwards in all gears ive redone linkage on tranny and i know 4 a FACT!!!! That the linkage is good 2 go so any help is very much appreciated
Old Jan 24, 2017 | 09:15 AM
rexmburns's Avatar
Super Moderator
You need a trans rebuild. The failure you have described is very common.
Old Jan 24, 2017 | 09:20 AM
Default Fix
U can tell the gears are there whenever u put it in reverse it just doesn't move
Old Jan 24, 2017 | 09:41 AM
rexmburns's Avatar
Super Moderator
Google "4l60e sunshell failure" and you will learn all about what I am referring to.
Old Jan 24, 2017 | 09:51 AM
Transman304's Avatar
If it is binding in rev you have damaged rear planetary gears. Stripped shell will not bind in rev. It will have 1st and 3rd gears forward.
DBo42098
Aug 25, 2009 05:11 PM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
Cuppy
Jul 21, 2006 11:25 PM
jermag24
Engine & Internal
Jan 6, 2005 10:56 PM
