Transmission Problems?
Old Mar 22, 2018 | 10:26 AM
02BlazerZR2's Avatar
02BlazerZR2 is on a distinguished road
Default Transmission Problems?
Okay so I purchased a 02 blazer 4.3 auto 4x4 with a bad transmission. My buddy had a good used trans out of his blazer that I got cheap, installed it and shifted smooth for a few weeks. Earlier today I was driving to the gas station and on the way back home the Rpms started jumping up and vehicle was revving like it was in neutral barely pulling. Speedo is also jumping around like crazy but it had done that every now and then before for a few seconds and would work like normal. Any ideas what it could be? I have read that a bad speed sensor could cause this but I’m not sure about it? Any input would be appreciated thanks.
Old Mar 22, 2018 | 03:06 PM
If the symptoms are coupled, then maybe a speed-sensor. However, if the transmission acts as if it has dropped into neutral with no other funny symptoms, it could be a clutch pack.
Old Mar 23, 2018 | 02:21 AM
newguy's Avatar
any other gears work? I lost 3rd and overdrive but 1st and 2nd worked. It was the clutch pack
Old Mar 23, 2018 | 06:41 AM
Transman304's Avatar
I agree with the other members post on that you have a 3-4 clutch pack failing. The speed sensor will definitely give you drive ability issues but not a slip while moving.
GloryImSaved
Jul 17, 2009 09:05 PM
upblazer95
Apr 4, 2009 08:27 PM
sfesenko
Dec 12, 2008 10:03 AM
vtlew
Jun 23, 2006 09:13 PM
SniperX13
Mar 21, 2006 04:02 PM
