transmission/rumble strip
Old Dec 14, 2009 | 08:47 AM
kse724's Avatar
kse724 is on a distinguished road
Default transmission/rumble strip
i just bought a 97 blazer..i haent driven it much, cause i have a transmission leak, but the little i have driven it, i believe its the transmission make shakes and makes sounds like i just ran over a rumble strips..i can feel the vibration at my feet when it does it too..id assume it does it at a certain rpm..but i havent driven it enough to notice when..anyone have any suggestions?
Old Dec 14, 2009 | 09:25 AM
More than likely it is something else in the driveline causing the vibration. Either a worn u-joint or a bad output bushing in the transmission (transfer case if 4wd).
I just had to replace the output bushing in the back of my dad's 2004 2500HD pickup. It had a bad vibration between 55mph and 70mph.
Old Dec 14, 2009 | 09:40 AM
kse724's Avatar
i tried googling it, and i seen u joint and torque converter mentioned the most for probable causes
Old Jan 22, 2010 | 12:56 AM
lax's Avatar
lax
lax is on a distinguished road
I'm having an almost identical problem. Have you found a definite solution yet?
Old Jan 22, 2010 | 02:39 PM
kse724's Avatar
no havent found whats up with it yet..it only does it rarely now so i been a little relaxed on figuring it out..i looked a bunch of forums onlne and so far im coming up with its probably the torque converter or ujoint
Tenagator
Jul 4, 2014 02:30 PM
ShawnS89
May 21, 2014 09:43 PM
blazinchevy
Jul 26, 2012 01:47 PM
jdcapri
Sep 26, 2011 08:34 AM
EXKid
Sep 20, 2010 11:23 AM
