Transmission shifting up and down on highway
Old Oct 25, 2012 | 02:53 PM
Blazer95_4x4's Avatar
Blazer95_4x4 is on a distinguished road
Default Transmission shifting up and down on highway
Hello
When I start my car cold and set it in OD and driving out on the highway the transmission starts around 54mph shifting up and down a few minuts. After a few minuts it`s stops shifing up and down. And the rpm shink to 1600 in OD. If i set it in Drive when it doing this, the rpm holds stedy on 2500. I hope you understand it.
Old Oct 25, 2012 | 04:22 PM
TZFBird's Avatar
TZFBird is on a distinguished road
I'm going to guess that it is the converter locking and unlocking. I would start by checking the fluid level. Either that or make sure your throttle position sensor is working correctly. That is one of the sensors used for transmission shifting.
Old Oct 25, 2012 | 04:39 PM
aa21830's Avatar
aa21830 is on a distinguished road
Pretty common thing on these trucks. Shift solenoid(s) can be part of the problem.
Old Oct 25, 2012 | 09:00 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default Agreed
The 4L60/e is notoious for having this problem.Other than shifting cylinoids causing it also it can be the boost valve that controls line presure or the proper presure of the fluid for shifting.Its recogmend to be changed at 75k.
Old Oct 28, 2012 | 05:22 AM
dave39's Avatar
dave39 is on a distinguished road
shift censor sounds likly but the B censor which control 2to shift to 3rd and 4th.most common problem on 4l60e is censors shift and boost valve failure. changing censors change boost valve same time only have to drop pan and filter. however it may not be tranny related at all it may be the tampon in fuel tank attatched to bottom of fuel pump clogged up had many cars do this and turned out clogged up pump strainer.makes jerking shifts back and forth if no jerking then go back to tranny censors and boost valve. but if reverse works good goes right in and grabs good boost valve not bad its main purpose is for reverse which needs the most amount of pressure more than likly shift censors theyre 18 dollars a piece at advcance auto hange both
bman22
Feb 18, 2013 10:00 AM
dave2800
Jul 22, 2010 09:33 AM
hmdmom2
Dec 6, 2007 09:25 PM
96jimmy4x4in
Oct 7, 2007 09:23 PM
Swblazer
Aug 15, 2005 01:41 AM
