Transmission slipping and leaking!!
Old May 20, 2009 | 09:05 PM
birchy82's Avatar
birchy82 is an unknown quantity at this point
Default Transmission slipping and leaking!!
Up until recently my transmission has been fine, just over 100k on it (99 blazer). Now I'll be driving and once at a cruise speed you can feel it jump and the rpm's go up and down. Once driving for a decent amount of time, it starts to leak out of the vent pipe that is next to the transmission dip stick...kind of embarassing with all of the smoke, from it leaking down on the manifold.
Any idea's?
Thanks,
Ryan
Old May 20, 2009 | 09:17 PM
Sounds like your torque converter is unlocking or slipping for some reason. This will cause the transmission temp to shoot up and can cause it to puke fluid out the vent line.
A plugged cooler line will also cause fluid to be pushed out the vent tube.
Old May 20, 2009 | 09:42 PM
birchy82's Avatar
Hmm...That could be a possibility...I did put a new engine in it...so maybe something got screwed up when putting it back in.
Old May 21, 2009 | 07:24 PM
Crestwood1001's Avatar
Crestwood1001 is on a distinguished road
And if ur leaking fluid and its slipping u prob shouldnt be driving it, can only cause damage and trannys are expensive
Old Jul 8, 2009 | 07:48 PM
paulggoo's Avatar
paulggoo is on a distinguished road
The problem is sometimes caused by a part in the transmission pump called torque converter clutch solenoid snout.
FD426
Apr 6, 2009 10:38 AM
ShadowHawk
Dec 9, 2006 12:52 AM
magtec
15
Nov 28, 2006 08:12 PM
timetoblaze
Nov 1, 2006 02:48 AM
MusicMaverick
Jan 26, 2006 03:27 PM
