transmission and speedo problems
Old May 25, 2012 | 09:25 AM
philsurfbum's Avatar
philsurfbum is on a distinguished road
Default transmission and speedo problems
Recently had a problem with my automatic transmission in my 2000 chevy blazer LS. The speedo stopped working and the car would only drive in second gear. The Brake warning lamp on the dash was coming on with this problem as well. The problem was intermittant at first and the mechanic couldn't find the problem, so $80 later they put it down to a loose electrical plug. A week later the problem reappeared permenantly. This time they found that the wiring between the VSS (vehicle speed sensor) and the computer was faulty. Another $150 and the problem is solved. Good to note that the car was still drivable in some sort of limp mode so we were able to drive (slowly) to the mechanic.
Old Jan 26, 2013 | 06:03 PM
JANIO's Avatar
JANIO is on a distinguished road
Default My Blazer 98
My Blazer is running engine but the transmission doesn't working,the shift move but nothing happen nor front nor backward.
Old Jan 26, 2013 | 08:12 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Sounds like total transmission failure
Old Jan 27, 2013 | 11:09 AM
neo71665's Avatar
First one sounds like might be the trans ECM went out.
The rude thread hijack sounds like trans wiped out.
S10BlazerFTW
Jun 16, 2013 03:35 PM
curtiesdad
Apr 16, 2012 11:24 PM
ineedatowel18
Jun 28, 2011 04:46 AM
wildmaninid
Jul 20, 2010 12:10 AM
bigdawgz2006
Nov 21, 2009 02:44 PM
