Transmission troubleshoot
Old May 1, 2009 | 09:42 PM
Blazerx85's Avatar
Blazerx85 is an unknown quantity at this point
Default Transmission troubleshoot
I have a very similar issue as "suckyblazer" It is like first gear is gone but I can put it into first manually. I had it coded and it brought up trans solenoid a couple times. I am hopeing someone here has delt with this and if just changing out the solenoid can solve this or is the trans shot? How hard is the solenoid to change cause while I am in there I was going to change the filter as well. Anyone with info I would greatly appreciate it.
Old May 1, 2009 | 09:58 PM
Solenoids are fairly easy to change.
Here are the two main shift solenoid A trouble codes:
P0751 - Shift Solenoid A Performance or Stuck Off
P0753 - Shift Solenoid A Electrical
Old May 1, 2009 | 10:05 PM
Blazerx85's Avatar
Alright thank you, how many total are there cause if I have to drop the pan and get up in there I would like to take care of all I can
Chris99
Feb 17, 2015 01:00 PM
able_onar
Jun 15, 2011 12:03 AM
GloryImSaved
Jul 17, 2009 09:05 PM
sfesenko
Dec 12, 2008 10:03 AM
Z Fury
Jul 14, 2008 08:36 AM
