Transmission will not shift into any gear.
This is for a 97 Blazer with a 4L60E. During the engine swap I changed the torque converter with a remanufactured one from Trans Star. A buddy of mine said that I had to run the shifter from park to first a few times to circulate fluid through the transmission. After doing that I had to add about 5 quarts to get it where it should be. But the next time I started the engine to drive around the lot, the truck didnt go into gear, any gear it doesnt even try to pull forward a little bit when I put it in drive. There are no codes that popped up with this problem and no wierd noises.
Any guesses? Bad torque converter?
I dropped the pan to check the fluid condition and found that it was dark looking in color. There were small metal particles stuck to the magnet and a few peices of metal like shavings as well.
My question is, would burning up a torque converter explain the color and shavings. The fluid and filter were changed before the engine blew up.
Second, Ive starting prepping the engine for removal once again. I just need to lift it out. My next question is should I try a new torque converter? Or, just get a new transmission?
Thanks guys.
Thanks guys.
What do you mean by line pressure and how do you test it. After it warmed up the fluid level stayed pretty constant on the stick. I suppose ive jumped the gun though by getting ready to yank the engine again.
ssmith0386
Oct 19, 2014 12:47 PM
flowdog1972
May 30, 2011 06:44 PM
Boiler_81
Dec 2, 2008 10:04 AM
