Transmission won`t shift to 3rd
Old Feb 18, 2014 | 08:56 PM
sedonamike's Avatar
sedonamike is on a distinguished road
Default Transmission won`t shift to 3rd
On the 2001 Blazer ZR2 1st and 2nd shift fine but when it hits 35mph it doesn`t seem to want to shift to 3rd, What is causing this-is it something I could fix or will it need a rebuilt transmission?
Old Feb 20, 2014 | 08:14 PM
dkslayer88's Avatar
dkslayer88 is on a distinguished road
Does it still shift into third eventually? Have u tried manually shifting it? If it still shifts into third but late and hard you could have a sticking shift valve
Old Apr 12, 2015 | 04:18 PM
ludwigkicker's Avatar
ludwigkicker is on a distinguished road
Question Mine is '01 with similar issue.
Noticed that Blazer wasn't shifting from 2nd to 3rd. Hooked up computer and showed Torque Converter Control Solenoid was bad, so did a swap of the TCC, and BOTH shift control solenoids.
Still not shifting from 2nd to 3rd. Did check the valve in the one control solenoid slot, moved in and out nicely, so no issue there.
NEXT??
crazy_lady93
Sep 30, 2014 08:09 PM
87/96 wheeler
Mar 28, 2012 02:26 PM
flowdog1972
May 30, 2011 06:44 PM
adercott
Feb 24, 2010 12:55 PM
Cornhusker
Nov 1, 2009 05:57 PM
