trouble code
Old Mar 3, 2007 | 11:09 AM
sbhoney's Avatar
sbhoney is an unknown quantity at this point
Default trouble code
I need help. I have hadmy trans rebuilt two times allready. The shop is saying that I am blowing the trans to do the motot. They said it is throwing a 0341 trouble code and has a bad miss. I replace the cam positioning sensor about a year ago . The engine light has not been on and I did not get any codes until last night. The engine light came on so I scanned the truck and got the 0341 code. I went out and drove it a little bit later and the light went off. Any clue to what is going on or what the problem may be.
Old Mar 3, 2007 | 12:37 PM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
Default RE: trouble code
Um, rough idel is burning out your trany and caused it to be rebuilt TWICE. Now that is just odd. I would lay my bet on they rebuilt it badly to the need for a second rebuild.
CMP Sensor Circuit Performance (P0341)
There is your code from off the topic post on codes.
as for the trany needing a second rebuild, how long did it take before you needed the second rebuild?
Old Mar 3, 2007 | 01:24 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
What year is your truck, and how many miles are on it? I have seen the dist. gears wear out on these and when they do it throws the cam retard off and will set a code. I have seen them where they were so bad, that when you pull the dist. the gears are about as sharp as a razor. Korey.
Old Mar 3, 2007 | 06:08 PM
sbhoney's Avatar
Its a 95 blazer with 170,000 miles on it. The trans needed to be rebuilt a second time about 6 months after initial rebuild. My problem is that the trans shop pulled the code and told me that if I do not fix the problem they are going to void my warranty. I know I probably needed the second rebuild because they screwed up the first time. I kept leaking trans fluid. The truck does run rough and shifts from first to second gear real hard. I allready replaced the cam positioning sensor and still throw a code.
Old Mar 3, 2007 | 11:13 PM
Kordog's Avatar
ORIGINAL: Kordog
Just mark the dist, and pull it. Than check the gear, with those kind of miles on it I am willing to bet that is the problem. Korey
El_Beautor
Nov 11, 2009 09:13 AM
sickpuppy
Jul 8, 2007 12:41 PM
sh1520
Jul 6, 2007 07:49 PM
dashyman
Aug 14, 2006 05:30 PM
luvfroses
Jul 7, 2005 11:44 PM
